Gaffrig Superflo 4.5" mufflers
I have two pairs of these. These mufflers worked AWESOME to reduce the noise when closed. These were freshwater mufflers, so no salt rusty junk. However, one of them has a little cosmetic damage, from the upper tie bar hitting it. Doesnt affect the operation, just cosmetic. Im sure a stainless welder can pretty that one up a bit, or just run as is. I'll try to get some pics tonight.
They come with all air cylinders, and I believe i have a pump for them. These can be made to work on a 4" tip setup also. I'll take 900.00 for everything plus freight. Heres a link to the superflo's. 2884.00 new from Gaffrig. http://www.gaffrigperformance.com/Pr...SubCategory=13 |
mufflers
can you check if you have the pump? only need one set, so just seeing the cost vs. new... thanks
Originally Posted by H2X BOSS
(Post 3678416)
If H2X takes one pair plus the pump, I may be interested in the other pair. I already have a pump from my Silent Choice setup. I may even take the one with damage, depending on how bad it is. Need pictures. How much will you want for the pair?
Thanks! |
2 Attachment(s)
Heres a shot of the mufflers. You can see the damaged one. The others all look like the other one, very nice.
| All times are GMT -5. The time now is 05:28 AM. |
