-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Rockford fosgate 10" subs (https://www.offshoreonly.com/forums/swap-shop/279074-rockford-fosgate-10-subs.html)
joe27baja 06-20-2012 06:37 PM
I have a pair of Rockford Fosgate M210S4 10" subwoffers. This set of 10s made some awesome bass Im my boat but as always Im never satisfied so I pulled them and went with with 4 12" subs... So I have no use for them anymore but you may. They have very little playing time on them.
I paid $225 each just over 2 months ago...The first $150 takes them (shipped to your door inside the continental U.S.)
This Is from the Rockford Fosgate site:
The M210S4 is a white 10” subwoofer designed for marine watercraft or powersports applications. It features a stainless steel grille is UV and moisture resistant and can be used in sealed, vented or infinite baffle installations.
•True Marine Grade compliance
•UV stable Centrex® injection molded plastic parts
•Proprietary corrosion resistant gold plated bare-wire input push-type terminals
•Injection molded mineral filled parabolic polypropylene cone body with UV inhibitors
•UV and Salt-Fog resistant TPE (Thermo-Plastic Elastomer) surround
•16 gauge corrosion resistant removable Stainless Steel grille cover insert
•Internal magnetic shielding for reduced electromagnetic interference potential
•Fully insulated ultra-flexible lead wire
•High temperature Kapton® former with polyimide insulated copper wire
•Moisture, tear and fatigue resistant aramid fiber spider
•Linear, high excursion matched motor magnetics and suspension design
. 250 watts rms / 500 peak
http://i75.photobucket.com/albums/i3...A/100_2086.jpg
http://i75.photobucket.com/albums/i3...A/100_2091.jpg
http://i75.photobucket.com/albums/i3...A/100_2093.jpg
http://i75.photobucket.com/albums/i3...A/100_2085.jpg
http://i75.photobucket.com/albums/i3...A/100_2087.jpg
mjdupuy 06-20-2012 07:17 PM
Hey I'm in Springfield and would be interested in getting those from you. Send me a txt or give me a call 985-981-7491
docbones 06-20-2012 08:39 PM
pm
check pm
joe27baja 06-20-2012 09:06 PM
deal pending...
Powerquest230 06-20-2012 09:45 PM
Joe please put me down as a backup if pending deal doesn't work out. Thanks, Rick
Dean Ferry 06-24-2012 12:04 PM
Joe,
If no one else buys them, let me know, I'm ready with cash in hand.
Thanks,
Dean
