-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Gil Manifolds & Dry tails Bravo Standard (https://www.offshoreonly.com/forums/swap-shop/280094-gil-manifolds-dry-tails-bravo-standard.html)
Baja226sport 07-06-2012 08:37 AM
10 Attachment(s)
I have a set of Gil (not mercruiser gil, actual Gil offshore) manifolds with long dry tails that I was going to use on my Scarab but I changed my mind.
Just looking for what I paid, $900
They are standard height, bravo set up. I will include a set of transom rings as well.
From the front of the flange to the end of the pipes is about 34" and from the base of the flange to the top of the riser is about 5"
hullofjustis 07-06-2012 08:53 AM
I want them as long as they will work can you send pics please to [email protected] or text 410 241 5796
FBRONCO 07-06-2012 09:18 AM
Let me know if they are still avail. I'm interested. pics to [email protected]
fantastixvoyage 07-06-2012 11:45 AM
Curious, what is the overall length?
Oh ya and put me third in line
Baja226sport 07-06-2012 03:10 PM
2 Attachment(s)
Also, 1 picture show the length compared to a long wet riser.
These pipes have been completely closed off at the end. ZERO water mixes with exhaust so they are EXTREMELY loud. The 3 holes in the bottom of the pipe are where the water exits. This is a modification that was done by Hardin Marine.
NOT ROT OR CORROSION ON THESE MANIFOLDS!!! I would spray them with fresh paint though, they are scratched from being moved around the garage alot.
fantastixvoyage 07-06-2012 03:16 PM
Thanks, looks close to what I have. I bought a set that the guy wasn't positive was for a bravo but took a chance. Cant find the overall length of tails confirmed to be for a bravo setup anywhere is all. No problem if you don't have this...should know this week if they fit one way or another lol
Baja226sport 07-06-2012 03:23 PM
I did list the overall length above. from the front of the flange to the end of the pipe it is 34"
Baja226sport 07-06-2012 04:14 PM
Sold pending pick up
fantastixvoyage 07-07-2012 12:42 AM
Thanks for the measurement, must have missed it the first time. Looks to be the same set I have. Let me know if the deal falls thru.
Baja226sport 07-08-2012 10:17 AM
sold!
