-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   496" stroker - mild 580hp Champion Performance built, dyno time only (https://www.offshoreonly.com/forums/swap-shop/281766-496-stroker-mild-580hp-champion-performance-built-dyno-time-only.html)
fantastixvoyage 09-13-2012 11:07 AM
I should have a copy of the dyno sheet to snap a pic of. Also have cam information, let me dig that up. Should be similar to the 741 that was on backorder forever.
Unlimited jd 09-13-2012 11:38 AM
.030 over would make it a 489", .060 from std 454 bore would be 496. Just FYI, still within safe limits of a mkIV block.
Tommybaja 09-14-2012 04:27 PM
Interested in selling the cmi's separate? Are they wet or dry?
fantastixvoyage 09-15-2012 01:23 PM
2 Attachment(s)
Cam is a Crane hydraulic roller HR-240/365-2S-12
Dyno sheet attached with max power of 582hp@6000rpm / 560ft-lbs @4500. Very flat torque curve over 560 from 3500 - 5200rpm.
fantastixvoyage 09-15-2012 01:26 PM
Will sell CMI's seperate. I'll make another ad for those.
fantastixvoyage 09-18-2012 08:30 AM
$6500 FIRM - no exhaust but otherwise complete. Keep in mind this is a fresh build from one of the best shops out there with dyno time only. Like to keep it but just dont have a use right now.
Duffer 09-18-2012 09:05 AM
Originally Posted by fantastixvoyage (Post 3744862)
Stroked 454
Also I have no problem swapping out the valve covers for all the non-sunsation owners out there.
How much do you want for the Sunsation Valve Cover?
dgncustoms 09-19-2012 11:46 PM
How bout selling just short block?
fantastixvoyage 09-20-2012 09:29 AM
Dont really want to split this package up as its fresh and dyno tuned. What are you looking for in a short block? I have a short block going to Champion soon that was going to be the base for a blower build but may be interested in selling as I have all winter to build new power.
fantastixvoyage 09-26-2012 01:57 AM
Bump once again before I start listing on other sites
