-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Teague ST-450 Switchable Exhaust (https://www.offshoreonly.com/forums/swap-shop/281785-teague-st-450-switchable-exhaust.html)
endeavour32 10-16-2012 10:53 PM
Bump.... Thanks for answering his question Eric.... I've been MIA for a while.
Budman II 10-17-2012 01:33 PM
Do you have the switch and wiring harness that goes with them? Friend of mine has these on his boat, and they work nice, but I am concerned that I won't have enough room under my hatch between the collector and the tip. To complicate things, mine was small block originally, so there is an alignment issue. I'll have to take some measurements and mull it over.
endeavour32 10-25-2012 08:11 AM
ttt
endeavour32 11-02-2012 07:50 PM
ttt
endeavour32 11-23-2012 12:40 PM
bump
endeavour32 12-05-2012 10:23 AM
ttt
endeavour32 01-23-2013 11:25 AM
Bump!
endeavour32 01-28-2013 07:07 AM
bump
liquidlounge 01-28-2013 10:52 PM
I'm surprised someone hasn't snapped these up. They are really an excellent product. A great way to run them is to keep your through prop exhaust (utilizing a Y pipe into...like a captains call w/o the valve) You can pretty much run wide open with any motor that will take a short riser. The motor will run really quiet and just under max performance.
endeavour32 01-29-2013 08:46 PM
I'm rather surprised I still have these as well. Spring is coming- they will be gone soon.
