-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   HP Transom and 1.36 Drive w/Max Tower (https://www.offshoreonly.com/forums/swap-shop/284410-hp-transom-1-36-drive-w-max-tower.html)
fantastixvoyage 09-08-2012 02:39 AM
1 Attachment(s)
Bravo 1 1.36 ratio with max tower, nosecone, studded top cap, drive shower and additional custom cooling (see pic). I bought used off OSO with supposedly a fresh build with upgraded bearings, etc. Seems like a nice unit but the ratio did not work for me with a single vee so only used for a couple runs. Currently has an Imco shaft for extension box and 1" spacer modified to work with tower.
$3200 or $2800 with stock input and no spacer.
HP Transom Assembly, very clean seems ready to bolt on and go. Includes inner plate, pump, transom seal and drive install kit. $1600
fantastixvoyage 09-15-2012 01:41 PM
Bump, make offer.
Have stock length input shaft so no problem to return to stock if the input and/or spacer is not needed.
fantastixvoyage 09-18-2012 08:12 AM
Bump
fantastixvoyage 09-26-2012 01:55 AM
Make offer
