tightturbo |
01-28-2013 03:21 PM |
460 ford 340 hp Redline marine engine
Complete 460 ford marine engine built by redline marine engines closed cooling system and remote oil coolers totally complete right down to the marine wire harness we test ran this engine on the stand and it seemed to run very well, oil pressure at idle was 60 lbs and compression is as follows 1-110 2-120 3-125 4-125 5-125 6-120 7-115 8-120 The carb could use a rebuild.The two brackets for the cooler are missing but are readily available 2000.00 email or call for pictures 541 821 0068
