468 Gen 4 420 base
4 Attachment(s)
I have a 468 has about 50 hours on it. Base gen 4 4 bolt started as a 420. Has a holley 850 marine, Eddie Marine flame arrestor, Edlebrock air gap intake, pro comp roller rockers, Imco valve covers, Iorn Eagle heads, Comp Cam, Comp chain, Trick FLow lifters, SRP pistons, Auto Lite Racing plugs, Gil 10 qts pan, Sea pump impellor just done, Brackets pulleys intake valve covers dist. hold down just powder coated. Thunder Bolt IV ignition MSD coil. Fuel water seporator. Bellhousing and coupler also included. I have a rear off shore plate if wanted but the front plate not included. I have a cross over and water outlet for it just waiting on it from UPS. Exhaust is KE 4.5 inch wet tails. Im haveing a bracket maching to hold oil filter. I used new hardware for barckets, exhaust, and intake.
Also have a set of Gil Manifolds and risers that i can swap out if wantedPretty much a brao drop in less harness 5200 B/O I have another motor for sale also. WHat ever sells first I am keeping the oter for my project Thanks Mike |
2 Attachment(s)
Put the cross over on and water outlet. Also put the connector hose on. I have a Holey Blue (110) gph and mallory reg for the motor included
4900 OBO have another project
| All times are GMT -5. The time now is 11:22 PM. |
