-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Bravo 1 Transom assembly complete (https://www.offshoreonly.com/forums/swap-shop/293477-bravo-1-transom-assembly-complete.html)
toyo321 03-24-2013 12:48 PM
I have a complete Bravo 1 transom assembly and transom plate. The pins and the upper steering arm are tight, no slop. $500 or BO
I will send pictures to once I get it back to the garage and cleaned up.
Thanks for looking.
gellis11 03-24-2013 03:04 PM
What year? Can you send pics to [email protected] Fresh or salt water? If in good shape I'll take.
gellis11 03-24-2013 03:22 PM
I am rebuilding a 454 and it will have too much power for my alpha ss. Looking to replace with a bravo.
toyo321 03-24-2013 04:06 PM
I had this on my 1994 Wellcraft Nova. I need to clean it up. It was in fresh water. It was pulled for my upgrade with my new BBC 540. It worked absolutly fine. There was nothing wrong with it. But like I said it needs to be steam cleaned. Typical green scum that it gets on the outdrive after sitting in the lake last year. I will clean everything up and send you the pictures in the next few days. If that is okay.
gellis11 03-25-2013 07:17 PM
ok
gellis11 04-01-2013 04:09 PM
Do you still have the transom? I still want it.
