-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   EMI Thunder SBC (https://www.offshoreonly.com/forums/swap-shop/294232-emi-thunder-sbc.html)
mile2885 04-07-2013 08:04 PM
EMI Thunder SBC
EMI Thunder for SBC. These came on a boat I'm rebuilding. I have not run the manifolds, the previous owner stated the boat was ran exclusively in saltwater. I'm not sure how old they are. Exhaust has corrosion on the inside and one area of visible pitting near the treaded bung. The threaded bungs don't look pretty but I have pressure tested the manifolds by plugging one water outlet and pressurizing with 15 psi air pressure (See picture). Each manifold held the 15psi for over 24 hrs. I only did a visual inspection on the risers but did not notice any cracks etc. The risers do have corrosion from the saltwater use and are not perfect. Outside has surface on both manifolds have scratches. Bolts and exhaust gaskets are not included. Can send picts if interested. MAKE OFFER
