-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   10051107 blocks (https://www.offshoreonly.com/forums/swap-shop/295833-10051107-blocks.html)
eliminatethis 05-05-2013 10:43 PM
10051107 blocks
I have two 10051107 Bowtie blocks new in the oem crate & bag. Anybody have a idea what there worth? I am looking to sell them. [email protected]
eliminatethis 05-06-2013 03:33 PM
worth that much :poopoo:
wannabe 05-06-2013 05:50 PM
thats the old gen IV bow tie block so an engine builder is your best bet when they want to match it up. Try PM's to few on here who may have a need. If new I would say 1200 to 1500?
Wannabe
Baja226sport 05-06-2013 06:21 PM
I would post them on racing junk. I think your more likely to find someone looking to build a 454 for a car. You know that they are considered "small" here. Even though you can still make big power and go plently fast it seems hard to get paid here for 454's even if they are bowtie siamese bore blocks.
Or even look for a jet boat site.
eliminatethis 05-12-2013 11:15 AM
Thanks I understand.
ledgeharp 05-13-2013 05:52 AM
interested in blocks 603-279-7676
TomFTM 05-13-2013 08:28 AM
You can make much more than 454's with these blocks .straight from gm book.. :poopoo:
10051106 — Bow Tie Block (Short Deck)
This “CNC” cast iron Mark IV Bow Tie block is strong foundation for any
serious big-block engine project. This “short-deck” heavy-duty block was
designed to meet the needs of Pro Stock drag racers, offshore boat racers,
and other competitors for powerful and dependable 500ci engine. The Bow
Tie block’s cylinder wall are “siamesed.” A Bow Tie big-block can safely be
bored to 4.500" because there are no water passages between adjacent
cylinders. The deck surfaces are reinforced and the lower head bolt holes are
blind tapped to improve head gasket sealing. Four-bolt main bearing caps
and reinforced cylinder barrels add strength to the Bow Tie block’s bottom
end.
Technical Notes: This block has semi-finished 4.250" diameter cylinder bores.
The distance from the crankshaft centerline to the deck surfaces is 9.800". It
has provisions for a mechanical fuel pump. Casting P/N 10051107.
ledgeharp 05-25-2013 05:47 PM
Hi do you still have the blocks call me 603-279-7676
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
