Rev 4 23 P RH - $235
7 Attachment(s)
I have this right hand 23 pitch Rev 4 prop for sale. $235 to your door. It has a few very small dings on the leading edge of one of the blades. This is a solid hub prop of the newer style with the replaceable splines. The splines appear to be in excellent condition. It runs nice with no vibration etc. I purchased this prop to try out and it looks like I need more prop. I had heard many good things about the Rev 4's on deep prop shaft boats but it looks like I will need a 25p. I would be open for that trade. In the interest of total candor I did buy this used so cannot say for sure it has not had some work done to it. Someone with more experience than I may be able to tell from the pictures.
Dan [ATTACH=CONFIG]501527[/ATTACH][ATTACH=CONFIG]501528[/ATTACH][ATTACH=CONFIG]501529[/ATTACH][ATTACH=CONFIG]501530[/ATTACH][ATTACH=CONFIG]501531[/ATTACH][ATTACH=CONFIG]501532[/ATTACH][ATTACH=CONFIG]501533[/ATTACH] |
It turns out that this prop is not what I thought it was. It is for an outboard application. The hub diameter is 3 7/8 inches. If it will work for you I will make you a great deal.
Thanks, Dan |
| All times are GMT -5. The time now is 06:58 AM. |
