-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Fuel System up for grabs cheap (https://www.offshoreonly.com/forums/swap-shop/299854-fuel-system-up-grabs-cheap.html)
l_sotero 07-16-2013 12:32 PM
2 Attachment(s)
[ATTACH=CONFIG]504507[/ATTACH][ATTACH=CONFIG]504508[/ATTACH]Entire very Low Time fresh water use, off 1999 Top Gun.
Fuel system...
2 electric fuel pump all the plumbing 2 fuel filter/water separator
With fuel mounting brackets,
2 Raw Water Pump(brand new impeller kits)with attached additional mechanical fuel pumps..
Every thing $350.00
whiskeyhangover 09-30-2013 08:08 PM
Do you still have this?
l_sotero 09-30-2013 08:10 PM
Yes we do...
whiskeyhangover 09-30-2013 08:19 PM
Will it eliminate the VST system? I have twin 502 EFI'S
l_sotero 09-30-2013 08:22 PM
to tell you the truth I'm not sure the system came off a set of file to blower motors .with dual carbs..
l_sotero 09-30-2013 08:24 PM
To tell you the truth I'm not sure the system came off a set of file to blower motors .with dual carbs..
whiskeyhangover 09-30-2013 08:25 PM
Ok thanks
