-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Bravo transom assembly (https://www.offshoreonly.com/forums/swap-shop/300358-bravo-transom-assembly.html)
captbones 07-25-2013 08:29 PM
3 Attachment(s)
I have a used bravo transom assembly that will need rebuild. Have most parts for this was taken off and replaced with an HD assembly. Ring is in great shape, gimbal and helmet as well. Just really needs new bellows, shift cable and bushing ect..... Have the old top steering pin blasted and all cleaned up, you decide is you want to use or not. Missing the tilt rams and lower steering pin on the bottom. Make a reasonable offer plus the ride and it is your.
[ATTACH=CONFIG]505048[/ATTACH][ATTACH=CONFIG]505049[/ATTACH][ATTACH=CONFIG]505050[/ATTACH]
captbones 07-27-2013 03:09 PM
ttt
captbones 07-30-2013 04:38 PM
bump
captbones 08-01-2013 08:44 PM
Nobody has a busted ring or next parts? This is a nice complete setup with the Steering pin for cheap. I see rings selling for 400.00 alone and pins for 200.00. Good deal for cheap parts.
captbones 08-06-2013 01:25 PM
bump
captbones 08-10-2013 06:07 PM
bump
motor 08-11-2013 07:39 AM
Can you provide a good closeup picture of gimbal housing where the steering pin goes through from the outside ..specifically the stepped area that is supposed to hold a seal .
Also a picture inside square hole at top of gimbal ring ...thank you
Fixxxer22 08-11-2013 02:52 PM
pm
captbones 08-11-2013 10:51 PM
Motor will do this week. Most likely tomorrow.
motor 08-13-2013 06:54 PM
pic? and bump
captbones 08-19-2013 08:19 PM
Motor,
Been real busy with another project. I will post those pics up tomorrow for ya.
