-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   JL Audio MX770-CCX-CG-WH (https://www.offshoreonly.com/forums/swap-shop/302369-jl-audio-mx770-ccx-cg-wh.html)
pstorti 09-02-2013 08:16 AM
I have two pairs of these speakers available both in great condition, they are no longer needed as I upgraded my buddy's boat to 8.8's. One speaker was replaced at some point under warranty that is why it looks different on the back. I also have brand new SS screws from JL audio, we had to use longer ones for the 8.8's.
$150/pair shipped
http://i272.photobucket.com/albums/j...psa58f4349.jpg
http://i272.photobucket.com/albums/j...ps520adb8d.jpg
cig20 09-02-2013 10:53 AM
what is cut out size and how old are they
slickwilly382 09-02-2013 08:33 PM
6 inch ?
pstorti 09-03-2013 07:08 AM
Here are the specs from JL's website http://www.jlaudio.com/mx770-ccx-cg-...x-series-91925
They are 7.7" speakers, cut out size is 6.25" and they are 2010 speakers, came out of a 24 Yellowfin bay boat.
General Specifications
Continuous Power Handling (RMS) 70 W
Peak Music Power 225 W
Recommended RMS Amplifier Power (per Ch.) 20 - 150 W
System Efficiency 90.5 dB @ 1 W / 1 m
System Nominal Impedance 4 Ω
System Frequency Response 45 Hz - 25 KHz ± 3 dB
Coaxial Physical Specifications
Frame Outer Diameter (A) 7.70 in / 196 mm
Bolt Hole Circle Diameter (B) 6.92 in / 176 mm
Motor Overmold Outer Diameter (C) 4.27 in / 108 mm
Frontal Grille Protrusion* (D) 1.00 in / 25 mm
Mounting Hole Diameter (E) 6.25 in / 159 mm
Mounting Depth (F) 3.15 in / 80 mm
ramos45 09-03-2013 01:14 PM
PM sent.
pstorti 09-03-2013 03:26 PM
Got all the PM's speakers are tentatively sold due to be picked up Friday, if for some reason that falls through I will reach out to the people who messaged me and see if we can make a deal, Thanks.
Bernie5131 09-23-2013 11:39 AM
Do you still have them ??
I'm here in Miami ,,what is the bottom price since i can pick up ??
txt me 786-222-4507
