-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Bunchastuff (https://www.offshoreonly.com/forums/swap-shop/302982-bunchastuff.html)
1 MAIDEN AMERICA 09-15-2013 07:03 PM
Bunchastuff
1-35-16595T oil filter $5
2-35-16595Q oil filter $5 ea
1-18-7876 fuel filter $5
2-Bravo prop locks w/same key http://shop.mcgard.com/mcgard-74039-...r-omc-set-of-1 $50 for set (missing plastic covers)
1-handheld Garmin GPS 12 http://www.ebay.com/itm/Garmin-12-Ch...item2a30ca4cd7 $100
2-Hardin SS H2O pump housings http://www.hardin-marine.com/p-14544...rhaul-kit.aspx $100 ea
2-plastic pump housings http://www.hardin-marine.com/p-14477...epair-kit.aspx $30 ea
1-dual -12 dump http://teaguecustommarine.com/plumbi...-body-751.html $40
3-90* SS 1"NPT-1.25"hose http://teaguecustommarine.com/plumbi...w-hex-nut.html $40 ea
2-straight SS 1"NPT-1.25"hose http://teaguecustommarine.com/plumbi...w-hex-nut.html $25 ea
1-SS sea strainer basket only. Teague U-RT with 1"NPT in/out, 1/2"NPT for pressure relief, and -12 for flush adapter http://teaguecustommarine.com/plumbi...ngs-30941.html $200
1-Gaffrig digital speedo w/recall and antenna. White face w/platinum bezel http://www.gaffrigperformance.com/Pr...m=42&prdt=4021 New $200
2-IMCO splash plates w/o shower holes http://imcomarine.com/cal_store/driv...plate-kit.html $40 ea
2-Bravo rear caps $50 ea
1-Bravo 1.25" prop shaft hub kit http://www.ebay.com/itm/MERCURY-RACI...58c566&vxp=mtr $40
Drock78 09-15-2013 10:25 PM
Im not able to view with any of your links.
1 MAIDEN AMERICA 09-16-2013 01:49 AM
Hmmm
1 MAIDEN AMERICA 09-16-2013 01:51 AM
Hmmm. Beats me. Try here. http://www.nwoffshore.com/forums/sho...?threadid=4376
COOPS 09-16-2013 07:39 AM
I will take both the plastic housings if they are complete kits.
1 MAIDEN AMERICA 09-16-2013 09:46 AM
They are used but very useable.
Kirkc 09-16-2013 10:40 AM
I am interested in the dual -12 dump, the SS H20 pump housings and your hose fittings. Are they used or new? Can you send pics to [email protected]?
Thanks,
Kirk
1 MAIDEN AMERICA 09-16-2013 11:55 AM
Thanks,
Kirk
Used but look new. No impellers or bolts for the housings, stock bolts work though. I'll try and get you pics tonight.
COOPS 09-16-2013 12:26 PM
Pm sent
carolinacopters 09-16-2013 08:29 PM
Pics of the speedo please to [email protected]
