-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   509" bbc short blocks, bowtie, carillo, venolia, etc (https://www.offshoreonly.com/forums/swap-shop/305322-509-bbc-short-blocks-bowtie-carillo-venolia-etc.html)
x454gtox 11-13-2013 02:17 PM
I posted a thread for the complete long blocks but figured someone may be interested in short blocks only.
509ci Big Block Chevy Short Block Engines (2 Available)
GMPP Bowtie Block - 4.5” Bore – Siamese Bore
Forged Non Twist Cranks – Standard – Not Turned Down
Carrillo H-Beam Rods
Venolia Forged Flat Top Pistons
Clevite H Series Rod and Main Bearings
Speed Pro Plasma Moly File Fit Rings
Engines were completely dissembled, cleaned, checked, and freshened less than 75hrs ago. I performed a leak down test with the heads installed and all cylinders were 76-78 out of 80 (less than 5% leak down which is VERY good). Oil filters were cut open and inspected after each oil change with no signs of metal at all. Engines ran fantastic at all times with zero issues. These are used assemblies and therefore sold as-is.
Engines are still assembled long blocks which I can send pics of.
Asking $3500 ea or $6500 for the pair.
Feel free to call or text 208-406-3016 with questions
