-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Crane 168741 Hyd Roller Camshaft (https://www.offshoreonly.com/forums/swap-shop/306628-crane-168741-hyd-roller-camshaft.html)
Ghostrider 12-21-2013 10:06 PM
I'm putting up for sale my spare Crane 168741 Hydraulic Roller camshaft to suit Gen 6 BBC 454-502ci.
Arguably one of the best aftermarket camshafts available from Crane.
I have no idea what they're worth these days or whether you can still get them from Crane Cams.
Open to offers, it's as new in the box so let me know what you think it's worth.
Here's the specs:
Part Number: 168741 Grind Number: HR-236/359-2S-12 IG
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1996 Up CHEVROLET 8 ROUGH IDLE, PERFORMANCE USAGE, GOOD MID AND UPPER RPM TORQUE AND HP, MARINE PERF. 3400-3800 CRUISE RPM, 10.0 TO 11.5 COMP. RATIO ADVISED. BASIC RPM 3000-6500
Engine Size Configuration
454-502 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 359 @Valve 610 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 372 @Valve 632
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 38.0 BTDC 80.0 ABDC 298.0 °
Exhaust 86.0 BBDC 40.0 ATDC 306.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99896
Loads Closed 132 LBS @ 1.906 or 1 29/32
Open 414 LBS @ 1.306
Recommended RPM range with matching components
Minimum RPM 3000
Maximum RPM 6500
Valve Float 7000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 11.0 BTDC 45.0 ABDC 107 236.0 °
Exhaust 59.0 BBDC 5.0 ATDC 117 244.0 °
Borgie 12-22-2013 12:53 AM
Summit racing sells the crane 168741 for $490 shipped FYI. http://m.summitracing.com/parts/crn-168741
Ghostrider 12-22-2013 01:22 AM
Good to know, thanks I hadn't even thought of searching them!
carter38 12-23-2013 08:58 AM
Very good cam and sounds awesome.
Ghostrider 12-25-2013 05:50 PM
Does anyone want it?
hammerdown500 12-26-2013 05:19 AM
What do u want for it I may know someone
SCORPION 31FT 12-26-2013 08:50 AM
I can get one new for $340.00 thru a local distributor like Summit
SCORPION 31FT 12-26-2013 08:51 AM
So how much? Your shipping from your location has to be expensive?
Rattlesnake Jake 12-26-2013 03:42 PM
Both Summitt & Jegs list the 741 for $490.
Throttle Fever 12-26-2013 05:21 PM
Just bought Two of them direct from Comp a month ago for $480.00 each.
So price accordingly.
Ghostrider 12-26-2013 06:35 PM
Thanks lads.
Yes, shipping will most likely add about $50-65 knowing Aus Post.
I'd take $375 ONO plus shipping I suppose but I might try and sell it locally too. I just thought it best to see if anyone on here might need it first.
5050 01-15-2014 09:54 PM
Did you sell?
cmd1962 01-16-2014 11:55 AM
Be careful, had a couple in an AO that broke at the Dist. gear. According to Crane, they made that cam out of two different materials. The one you want is a copper colored forging. Just an FYI. If I'm wrong I apologize.
Ghostrider 01-16-2014 03:14 PM
You are total right mate, this one has that, apparently the early ones (same part no.) didn't.
Cam's still sitting here on a shelf if anyone want's it, not bothering me at all so not fussed either way.
Can post pictures if you like?
Eliminatorshane 01-16-2014 09:33 PM
Price ? Shipped to oklahoma.......
JAY WOHLTMAN 01-26-2014 08:09 PM
Hey do you still have the cam? Very interested
