Making ROOM, clearing shelves.
Im cleaning off some of my shelves trying to make some room. I do not strip or part boats, this just some stuff I have bought and or removed over the last few years I dont need as bad as I need the space! If it isnt listed as NEW it is used. Thanks for looking.
8 ea Comp cams magnum pushrods part # 7131 (used) 8 ea Comp cams magnum pushrods part # 7141 $45 + shipping Trick Flow pushrods (dyno only) 8ea 8.800" 8ea 7.900" $75 + shipping Crane Cams pushrods (40 hrs) 16ea 8.550" 16ea 7.550" $60 + shipping per set 1-Melling 10778 C oil pump w/ pu (Dyno only) $50 + shipping 1-Jabsco water pump, pulley and brackets $150+ shipping 2- Alternator, bracket and harness $75 + shipping 1-New style water pump/bracket, (missing a few bolts) $125 + shipping 1-MERC Distributor, plug wires, module, coil from 502 carb $125 + shipping 2-HP 500 oil coolers, lines and block adapter $125 + shipping each set up. 2-HP 500 water pump pulleys $25 each + shipping 8-JE 757F flat top pistons USED (0.040") over $200 + shipping 1-Procharger 3 rib v belt accy pulley USED $50 + shipping 1-pr 502 alum finned o-ring style black valve covers $50 + shipping 1-HP 500 dist and wires $125 + shipping 1-pr fabricated alum bbc valve covers w/bolts (NEW) $120 + shipping 6-MERC Thunderbolt IV v6 modules $75 + shipping each I can email pictures if your interested. Thanks. |
I will take ARP head studs, PM sent
PM sent
Coolers larger than 502 mag mpi oil coolers? If they are larger ill take them
ARP studs sold pending payment, Thanks Nedpole.
Oil coolers are larger than factory Merc 502 mags. About 2" dia x 15" long, Sold 5050 pending payment. Thanks! |
9186296271 text or call for payment arrangements. Thx
do you have an extra set of brackets for the HP500 cooler?
sea water pumps
Please email picks of us, brackets and pulleys.
I will take some of the are the correct ones for a 500efi Thx Larry |
Originally Posted by ldillow
(Post 4060091)
How bout pics of the new style water pump and the jabsco one.513-266-0516.
| All times are GMT -5. The time now is 08:22 AM. |
