Merc stuff. etc.
Bunch of Misc. Merc stuff.
For sale. Please check make sure what ever you want will work for you. I don't mind giving a refund, but I won't pay for back and forth shipping, so check you application. 600-6915 Area code 904 1) High pressure fuel pump from 496 HO Mag. Used but like new condition. Wrong diagnostics. ( jets needed to be cleaned, fuel pumps are fine) $100 2) Low pressure fuel pump. fuel pump from 496 HO Mag. Used but like new condition. $100 3) New High pressure fuel pump with cooler in original box, not opened. $200 4) Two refurbished starter for 454 /502. $60.00 7) Alum exhaust elbows. (about 1½ hour use) from 454 Mag. $125 8) One SBC exhaust riser. $35 9) Bunch of fittings. Most are for IMCO power steering lines and some for misc. connections. See picture let me know what you want. $5 to $15 each. 10) Holley carbs. Used. Planned to change from my Webbers but I would have to redo the injectors, so I just kept the old carbs. Not sure what CFM's are (750or850?) these so check the numbers. $150 ea. 12) SBC oil pump, one is used about 1-2 hours. $100. The other is new, never installed; $150 13) Stainless Speedo pick ups. 2 used, $15 one new. $35 16) Alpha one water pump housing, (lower) with all the gaskets. $10 17) SBC oil pan gaskets, and misc. left over gaskets I had duplicates. $ ? 18) SBC head gasket set. $15 19) Strainer (or ?) fittings. Brass.. 1" to 1" and 1 " to 1 1/2" (see pix) $20ea. Have 4 of ea. 20) Bravo XR, inner transom plate. $100 21) Set of Gaffrieg gauges for twins, white. (less water temp.) 22) CMI Underwater exhaust kit. $3,000 Custom made for an OL by CMI. (I won't be using it) Headers go into "Y" pipe, then out to bellow waterline with strainer. Cool set up, no mufflers needed. Once you on plane, no performance restriction. (E-mail for pix) |
What is the part number for the high pressure pump/cooler that is new in the box?
PM sent about gauges
861156A02 "fuel pump/cooler"
Your pm box is full. Send me your name and address and I'll get that out to you tomorrow. Thanks
Got the email with gauge pics. They look good. Get back to me when you get a minute.
Send pics of the power steering stuff to [email protected] Thanks
2 Attachment(s)
[ATTACH=CONFIG]517199[/ATTACH][ATTACH=CONFIG]517200[/ATTACH] PS stuff. I have most pictures, a few parts I used... or lost. lol
pick of the speedo pickups Thanks
1 Attachment(s)
[ATTACH=CONFIG]517231[/ATTACH]
| All times are GMT -5. The time now is 01:51 PM. |
