TRS STUFF 2 502's 2 454/420's and lots of other stuff
ALL STUFF LISTED IS FOR SALE. READ MY POST UNDER 1984 MIRAGE IN THIS SAME FORUM AND IT GIVES MUCH BETTER DETAILED DESCRIPTIONS.
2 454/420'S LOW HOURS UNDER 60, 1- 502 REBUILT, (1 502 LOW HOURS, GREAT COMPRESSION BUT SITTING FOR A WHILE. 1-502 SOLD) 4-TRS GIMBALS, 2-REBUILT, 2 LITTLE PLAY Fresh Gimbals $1100 4 TRS OUTDRIVES 2 NICE (sand blasted need to be painted) I purchased these because very good cosmetically and I knew who maintained the boat. ,Nice pair $2500 Ugly but functional ( more electrolosis divots than I like) $1800 2 O.E.M TRS DECAL SETS. YES I WAS THE AH THAT PAID $400 FOR THEM!!! OFFERS 2 NEVER MOUNTED HOLLEY 800CFM-CARBS SOLD!! 1 DART HP 500 STYLE INTAKE AND 800CFM EXCELLENT AND POWDER COATED BLUE $600 1-SET SHIFTER AND THROTTLES W TRIM SWITCH OUT OF AN EARLY TOP GUN, CLEAN $300 4 GIL MANIFOLDS, 4 RISERS LOW RISE LONG DRY 1-set Manifolds SOLD 2 HOLLEY BRAND NEW BLACK PUMPS FULL SET GAFFRIG GAUGES FROM OLDER FOUNTAIN WITH TWINS- OFFER 1-168731 CRANE CAM ,DYNO TIME $200 1-SET CRANE GOLD ROLLER ROCKERS FOR BBC, LOW HOURS, W/O LOCKS $175 HERE ARE THE SPECS FROM CRANES WEBSITE: 1996 Up CHEVROLET 8 FAIR IDLE, MODERATE PERFORMANCE USAGE, GOOD MID-RANGE TORQUE AND HP, MILD BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, MILD MARINE PERF., 3000-3400 CRUISE RPM, 9.5 TO 11.0 COMP. RATIO ADV. BASIC RPM 2500-6000 Engine Size Configuration ? 454-502 C.I. V ? Valve Setting: Intake .000 Exhaust .000 HOT Lift: Intake @Cam 345 @Valve 587 All Lifts are based on zero lash and theoretical rocker arm ratios. ? Exhaust @ Cam 359 @Valve 610 Rocker Arm Ratio 1.70 ? ? Cam?Timing: TAPPET @.004 Lift: ? Opens Closes ADV Duration ? Intake 33.0 BTDC 75.0 ABDC 288 ? ? Exhaust 82.0 BBDC 36.0 ATDC 298 ? Spring Requirements: ??Triple?? Dual?? Outer?? Inner Part Number 99896 Loads Closed 132 LBS?@ 1.906 or 1 29/32 ? Open 405 LBS?@ 1.326 ? ? Recommended RPM range with matching components Minimum RPM 2500 Maximum RPM 6000 Valve Float 6500 Cam?Timing: TAPPET @.050 Lift: ? Opens Closes Max Lift Duration ? Intake 6.0 BTDC 40.0 ABDC 107 226 ? ? Exhaust 55.0 BBDC 1.0 ATDC 117 236 ? 1- RITCHIE COMPASS BEZEL IS CLOSE TO MERC RACING BLUE $175 1- NEW IN THE BOX MARINE WATER PUMP FOR BBC MES PART NUMBER WP415-M- $85 1 SET 4 BLADE BRAVO PROP 26P . DECENT CONDITION NO GOUGES AND NO BENDS. $500/PAIR ALL PRICES ARE PLUS FREIGHT OR CAN I CAN ARRANGE TO DELIVER THE LARGE STUFF ANYWHERE ALONG I95 FROM N.J. TO LAUDERDALE SECOND WEEK OF AUGUST. . IF MAILBOX IS FULL TEXT ME AT 609.226.4485 |
Love to have that 502 but stupid house funds took my toy money! :poopoo:
How much for 800 holley ?
interested in the throttle and shifters, are they painted, or plated, alum ect
shifters are stock black, original
$250 a piece
pmed u give me a call 609 259 3273 rich
Interested in either one of the holleys.....or the hp500 setup....can you get me prices shipped to 77662 please...funds in hand.
Thanks 2 NEVER MOUNTED HOLLEY 800CFM 1 DART hP 500 STYLE INTAKE AND 800CFM EXCELLENT AND POWDER COATED BLUE |
how much for the shift are they still available pm me
| All times are GMT -5. The time now is 04:00 PM. |
