-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Demon Dominator Super cat Carb (https://www.offshoreonly.com/forums/swap-shop/317420-demon-dominator-super-cat-carb.html)
OCCJoe 08-29-2014 10:02 PM
5 Attachment(s)
Demon Carburator 4500 Dominator , I believe it's a 1095 . I could be wrong but I can investigate further if you need me to . Resonantly used it on a dyno but wound up going with my old faithful . In good shape , has fresh gaskets in it . $500 shipped........................................... ........... [ATTACH=CONFIG]528555[/ATTACH][ATTACH=CONFIG]528556[/ATTACH][ATTACH=CONFIG]528556[/ATTACH][ATTACH=CONFIG]528557[/ATTACH][ATTACH=CONFIG]528558[/ATTACH][ATTACH=CONFIG]528559[/ATTACH]
fantastixvoyage 08-30-2014 08:00 AM
Are there any numbers on it? If it was truly off a supercat it's likely way small, 750 comes to mind. That's one of the components they used to limit the power made. Nice carb just need to understand what it is
OCCJoe 08-30-2014 12:17 PM
I got it from Edd Smith when he took it out of the Clevand Construction Talon . I don't see any easy to find numbers on it . I will pull the bowl's and blocks of it and look around . If that doesn't produce anything can always have it flow tested
