Engine parts/ props
2 Dart 4150 fresh water only intakes $200.00 each
2 4340 one piece seal, stroker crank shafts, 4.25 stroke Magnaflux and polished $350.00 each 2 crane hydraulic roller lifter $275.00 per set 2 comp cams 647 lift 236 duration, provisional for thrust plate and able to run mechanical fuel pumps $180.00 each crower stud girdles $100.00 per set Pair of stock 34 pitch bravo 1 props $600.00 for the pair You may call or text me between 8am till 8pm. 716-390-7327 Thanks, Shawn |
Have the crankshafts been ground?
Originally Posted by tigweldersm
(Post 4196697)
have the crankshafts been ground?
Bump
Parts are all still available. I had them sold, however payment never arrived! Make offer!
what heads do the stud girdles fit?
std deck intakes?
Yes, standard deck intakes.
What brand are the cranks? Have they been drilled or welded for balance weight?
All engine parts sold, thanks OSO. Props still avaiable.
| All times are GMT -5. The time now is 08:33 AM. |
