-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   572 Dart block blower motor!!!!!! (https://www.offshoreonly.com/forums/swap-shop/320267-572-dart-block-blower-motor.html)
MuddyToy 11-18-2014 09:58 AM
Build Sheet is as follows: Dart Big "M" tall deck block with billet main caps honed to 4.500, JE dish blower pistons with a static compression of 8.27:1, Total seal rings with .022" top gap and .019" second ring gap, 4340 Forged Scat 6.535" connecting rods w/ARP 2000 rod bolts, Federal Mogul coated race bearings with .0025" rod bearing clearance and .003" main bearing clearance, Crower 4340 forged blower crank 4.500 stroke w/dual blower drive keyways, Melling HVX oil pump and moroso hardened pump driveshaft,Canton 10 qt offshore oil pan with complete windage and trapdoor oil scraper system with integral raw water pump mounting bracket,Comp Cams hyd. roller cam .621" lift and 260@ .050 intake and 270@ .050 exhaust duration, comp .080" wall hardened pushrods, Comp Cams Hyd roller lifters, AFR CNC ported 377cc intake runner cylinder heads with CNC ported 121cc combustion chambers, 2.30" intake valves and 1.88" inconel severe duty exhaust valves, Comp Cams ultra pro magnum roller rocker arms, ARP rocker studs and guide plates, TBS 1071 blower running 8% overdriven for 10.2 lbs. boost, twin QFT 950 cfm blower carbs, Race Pumps piston driven fuel pump and race pumps regulator all AN plumbed to carbs, MSD pro billet distributor with 18 degrees of timing advance, initial timing is 16 degrees and fully advanced @ 2800 rpm to 34 degrees total with pulling 3/4 degree of timing per lb of boost to make it 93 pump gas friendly with the msd 6BTM ignition box, melling dual roller keyway adjustable timing chain set, Clearances require Mobil 1 15W50 motor oil for 45 lbs oil pressure at idle and 60 psi off idle. Bob weight total for balancing is 2260 gr. Assembly is balanced to less than 1 gr. Dynod at 1009HP at 6100 rpm and 950trq at 4500rpm... If you wanted to run this on race gas it would be good for over 1500hp with more boost. Located outside of Lancaster PA.....$22,500!!!! I cant load photos here not sure why!!!!!! Let me get an email or text for pictures!!!!!
