Thunderbolt V Distributor / Cap, Coil, 8MM GM Perf Wires, Ignition Coil Wire - $125
Thunderbolt V Distributor / Cap, Coil, 8MM GM Perf Wires, Ignition Coil Wire - $75
Taken off a HP500 Carb, Worked Great with no issues. Thunderbolt V set up, Distributor / Cap / Coil (does not appear that I have the screws to hold the cap onto the distributor as well as any type of gasket the distributor shaft may need to sit onto the intake..not sure if there was one). The wires are GM Performance (set of 8) 8mm, the Ignition Coil is Moroso ULTRA 40 Race Wire 8.5mm.
$75 Shipped US for everything.
Probably a dumb question, but is there any reason I couldn't use this stuff on the Gen V 454 in my van? It's dues for a tune-up. I know you can't use automotive electrical parts in a marine application, but going the other way should be ok right?
