Melling Performance 10555 Oil Pump
I used this pump on my stock block 383. It has 247 hrs of run time. No engine failure. Upgraded to a Dart block and Dart does not advise a 25% HV pump. This pump is as new per Melling specs. Everything in pic is included.
$25 plus ride. http://i1378.photobucket.com/albums/...psdbbfbdc0.jpg High Volume performance upgrade for the 10550 oil pump. 25% increase in volume over stock oil pump. The 10555 is manufactured with the drive and idler shafts extended to allow for additional support in the cover eliminating dynamic shaft deflection at increased RPM levels. The cover is doweled to the pump housing to assure alignment of the shaft bores. Screw in plug retains relief valve spring instead of pin. Relief hole in cover uses screw in plug instead of pressed cup plug. All bolts are self locking socket heads, with the wrench supplied. The housing and cover are CNC machined and manganese phosphate coated. Includes intermediate shaft with steel guide. Uses both 3/4” bolt on or press in screen. The lower pressure spring is included to reduce pressure if desired. |
Ttt
$20 Any takers?
Sold
| All times are GMT -5. The time now is 03:40 PM. |
