-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Two complete EFI and Ignition (https://www.offshoreonly.com/forums/swap-shop/322548-two-complete-efi-ignition.html)
SME1 01-28-2015 10:29 PM
Two complete EFI and Ignition Systems
Two complete EFI and ignition. Perfect condition. These came off two Sterling Performance engines.
EFI System
  • ECU - EFI Technologies X3. Complete spec sheet here: http://www.efitechnology.com/X3.html
  • Wiring Harness - EFI Technologies Mil Spec Harness. Set Up for Port injection and Batch fire.
  • Mounting Brackets – Sterling Performance mounting brackets are machined and bolt onto supercharger studs. Includes mounting locations for IAC valves
$3,000 for both EFI systems including everything above
Ignition System
  • Ignition Module - MSD 6M Marine CDI
  • Distributor – MSD marine distributor
  • Coil – MSD Blaster Coil, high vibration.
  • Spark Plug Wires – Sterling Performance shield spark plugs wires
  • Wiring Harness – Wiring harness for ignition, coil, relays, etc…
  • Mounting brackets – Sterling Performance custom bracket for 6M2, coil, and harness
$1,500 for both Ignition systems including everything above
SME1 01-29-2015 07:28 AM
https://dl-web.dropbox.com/get/Used%...QIexP-mgK2SlUw
https://dl-web.dropbox.com/get/Used%...x5ceAud1yxckwQ
https://dl-web.dropbox.com/get/Used%...Oe24GwiZxCYXyA
https://dl-web.dropbox.com/get/Used%...txMgpVJ9hLXCaA
https://dl-web.dropbox.com/get/Used%...Gu7s3vvbzHDprQ
https://dl-web.dropbox.com/get/Used%...4fKVa4EfN3ABFg
adk61 01-29-2015 07:40 AM
pics didn't go through
where are you located?
SME1 01-29-2015 08:06 AM
Dallas, TX. Everything works and can be confirmed by Johny at TNT.I could also do face time if there are any specifics anyone wants to see.
SME1 01-29-2015 09:33 PM
bump
adk61 01-30-2015 07:50 AM
pm sent
SME1 02-04-2015 08:36 AM
bump
down2lb 03-08-2015 05:14 AM
sme1 can you send me pics 714-943-6355
