-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Shift / Throttle controls for single engine, like new also a fiberglass shifter pod (https://www.offshoreonly.com/forums/swap-shop/323665-shift-throttle-controls-single-engine-like-new-also-fiberglass-shifter-pod.html)
rslick 03-03-2015 11:35 PM
4 Attachment(s)
I have a Hardin Marine single engine throttle / shift control assembly. I believe it is cast aluminum. Like new, installed once and removed. One small paint chip on one corner. Trim switch in throttle handle and neutral safety switch included.. $375 plus the ride. Also have a new fiberglass shifter pod if you need that also. $100 plus the ride.
Black Baja 03-04-2015 05:45 AM
Can you get some dimensions of the opening of the pod and the depth of the opening? I ask because the base of my controls is are huge on the bottom side.
rslick 03-04-2015 04:26 PM
Opening dimensions are 6-5/8 x 2-3/4, fiberglass is 3/16 thick. Depths from the top of the opening down are; 12'' at the front of opening, 13-1/2 in the middle and 14-3/8 in the back of opening.
rslick 03-12-2015 02:26 PM
ttt
Nykamp 11-25-2015 09:16 PM
Did this ever sell?
rslick 11-28-2015 11:43 PM
Nykamp,
I still have both items.
rslick 01-18-2016 01:44 PM
ttt
monster12valve 01-19-2016 05:06 PM
Can you email pics to [email protected] please. I can't see the pic on the first post.
mickeymcclgn 01-19-2016 07:29 PM
I'll take the fiberglass control pod if 12valve doesn't want it. Just let me know your PayPal info and shipping cost to 21122. Thanks!
GLENAMY 242SS 01-21-2016 01:50 PM
What is still available please.
