I'm pretty sure the 575 sci has a pretty mild flat tappet.
That engine would have a hydraulic roller, not a flat tapped.
Originally Posted by TomZ
(Post 4284911)
:pacifier: |
Sorry guys but ALL FOUR serial ranges of the 575sci list the same camshaft and same lifter, and they are flat tappet. Not roller.
Just to clarify The 575 SCI (ALL Serial ranges) 1991-1996 Gen IV/V 600 SC 1998 Gen VI bobtail 600 SC 1993-1998 800 SC All run the Crane/ Merc # 491-818870 cam which is a a hydraulic flat tappet. |
That doesn't mean that your engine wasn't changed at some point, but if they were on a 100% factory stock 575sci they are set up for flat tappet. If that was a factory roller engine I would be trying to buy these already. I need something to bolt on and go just in case my other engine is not finished by the time the weather turns.....
These are off a bone stock 575SCI running a flat tappet cam. I can do a valve job and a spring change on them if that is what someone is looking for.
Originally Posted by snapmorgan
(Post 4285085)
525.00 shipped to 49675?
$100 should cover shipping to most areas of the country
| All times are GMT -5. The time now is 10:41 PM. |
