-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Merc Racing Cool Fuel Setup (https://www.offshoreonly.com/forums/swap-shop/324455-merc-racing-cool-fuel-setup.html)
snapmorgan 03-25-2015 10:04 PM
1 Attachment(s)
I have a used cool fuel setup for sale off a 575 SCI. Includes pump and cooler, regulator and lines. 2005 model with 140 hrs. All works perfectly. $300 shipped[ATTACH=CONFIG]538996[/ATTACH]
jvthundercat 03-26-2015 04:54 PM
First, is that factory Mercruiser?
Would it be the same one as my 2001 502 MPI?
F-2 Speedy 03-26-2015 05:20 PM
It looks to be the same as the 500 EFI, it will work for your application, the 502 MPI doesn't use that round silver fuel filter canister, and yes that's factory Merc. after looking closer I think the hose connections to the cooler is different than the 502 mpi
snapmorgan 03-26-2015 06:04 PM
Yes, it is factory Merc. I believe the fuel pressure is a little lower on this vs. the 502MPI. You would probably have to use your regulator to bump up the pressure or install an adjustable one.
F-2 Speedy 03-26-2015 06:08 PM
Is the bracket included
snapmorgan 03-26-2015 06:13 PM
Not currently. I am going to try and mount my new fuel pump on it. If that doesn't work out, I will include the bracket. Still waiting on my new pump to show up, so I don't know how well it is going to work out
F-2 Speedy 03-26-2015 06:20 PM
I'm converting my 540's like you, to Aeromotive but I'm going to put them where I can get to them not under the motor mount like these
snapmorgan 03-26-2015 07:14 PM
Take a look at the Weldon pumps and regulators. Nicer stuff for less coin.
KWright 03-26-2015 07:34 PM
I used the bracket off a 700sci. pump sits under the balancer makes for a clean install.
snapmorgan 03-26-2015 08:54 PM
Yes, this one sits under the balancer as well
