-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Dana HP1000 billet trim tabs complete system (https://www.offshoreonly.com/forums/swap-shop/326277-dana-hp1000-billet-trim-tabs-complete-system.html)
DCB FX 28 05-15-2015 05:46 PM
1 Attachment(s)
Dana HP1000 trim tabs system includes the following:
• Dana HP1000 billet trim tabs with hydraulic cylinders, 8 –12” wide x 22” long
• Brass thru-transom connector pipes with adaptor fittings for hydraulic lines to trim pumps
• Braided stainless hydraulic lines from cylinders to connector pipes and from connector pipes to trim pumps
• Parker Hydraulics Oildyne Div. trim pumps Mod. 108AMS-10 with solenoids installed on Dana mounting plates
• Blue Water Performance dash indicator panel Mod. DG3565750-S
• Morse 301947 tabs to panel connector cables
• Water seal fittings for indicator connector cables
• Stainless 3/8”-16 x 3-1/4”mounting bolts and nyloc nuts with aluminum backing plates
Note: This trim tabs system was removed from a DCB FX 28 V-bottom in good working order. The indicator panel shows trim tab position and drive position.
1800.00
getrdunn 05-15-2015 09:25 PM
Price seems right... I'll take them. Or wait a minute there is no price.
DCB FX 28 05-15-2015 11:19 PM
Sorry getrdunn, price is 1800.00. By the way, your Spectra looks like it's catching air around Charlevoix, or Petoskey.
How's your drive?
315duramax 05-16-2015 12:51 AM
thats not a bad deal at all... my top gun needs new tabs... and this is tempting
DCB FX 28 05-16-2015 01:06 AM
315duramax
Let me know. I won't be able to reply until the 27th of May if you want them.
