-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   SSM V drive set up (https://www.offshoreonly.com/forums/swap-shop/328271-ssm-v-drive-set-up.html)
Jrock 07-14-2015 08:24 PM
Originally Posted by Sick Stinger (Post 4330098)
get a spacer and put it on cheapest trial and error
Already have a 2" spacer on it. Still not enough. I heard that the 4s were 5" shorter than the 5s.
Sick Stinger 07-14-2015 08:59 PM
Why is the X so high? 2 inch spacer and you need more , it happens but that's way off. Did it have boxes and then removed?
Sick Stinger 07-14-2015 09:09 PM
If you want me to I'll measure my 5s to the 4s I'm getting this weekend I don't believe it's 5 inching that's huge.
Rbesola 07-15-2015 06:59 AM
4s and 5s are exactly identical from the outside
MILD THUNDER 07-15-2015 07:39 PM
Yep. 4 and 5 are same x dimension.
Sick Stinger 08-07-2015 08:41 AM
Also have 17 x 26 for these drives that are mint.
Have pics or I can post
Sick Stinger 08-10-2015 08:05 AM
Ttt
Crude Intentions 08-11-2015 02:03 AM
Out of curiosity is that for each drive or both mike?
Sick Stinger 08-11-2015 05:43 AM
That's both
Sick Stinger 08-11-2015 06:17 AM
Gimbals need work but I have another set also that are in much better shape
