-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Stellings headers from SSM app Blacks (https://www.offshoreonly.com/forums/swap-shop/328374-stellings-headers-ssm-app-blacks.html)
Sick Stinger 07-11-2015 07:58 PM
3 Attachment(s)
Have 4 sets (2 pairs) of stellings blacks.
2 sets have O2 bungs, 02s not included sorry
2 Sets do not. I pressure tested the 02 set at 25 psi for 10 minutes and sprayed with soap and water and checked welded as best I could
Both sets had mufflers on the so by no means are the perfect need some polishing and have marks from mufflers ect
2600 each set
4800 for 2 sets shipped
[ATTACH=CONFIG]542968[/ATTACH][ATTACH=CONFIG]542969[/ATTACH][ATTACH=CONFIG]542970[/ATTACH]
Python82 07-14-2015 01:54 PM
Did you pressure check the other set? Do you think they would work on my 85 Cig Mistress?
Sick Stinger 07-14-2015 02:08 PM
I haven't checked other set yet.
I will be able to check them next week at some point hopefully.
They can work on anything but hole orientation is obviously your issue. TRS/Bravo usually do not line up unless some one orderd the tails specific to that angle if they did stellings with a bravo TRS app
jaysflatdeck 07-14-2015 06:16 PM
Not here to cut sick stinger grass but if you don't buy his I have the set of headers that were on ur boat at one time I want to sell
Sick Stinger 07-14-2015 08:09 PM
If Jay has the rite ones if rec that but mine are available
Python82 07-14-2015 10:21 PM
Ok, thanks for the info.
