LH+RH 28p Bravo I 4-blade props, lab finished by B-Blades - LIKE NEW! TESTED ONCE!
(1) matched set 28p LH/RH Bravo I Labbed props:
-Labbed by B-Blades. (Conservative Lab - not overly thinned down for reliability) -I bought them brand new before that - they are in excellent/like new condition (1 owner) -Fresh Water Only. -No nicks, absolutely no repairs. -Tested on boat 1 time - props ran great and had incredible mid-range to top end pull. -Will ship in BBlade Boxes. Can not separate (matched pair). Asking $1,200 for the pair shipped (in US). See images below. Thanks! https://lh3.googleusercontent.com/-b...221_111702.jpg https://lh5.googleusercontent.com/-3...221_111254.jpg https://lh4.googleusercontent.com/-m...221_111325.jpg https://lh3.googleusercontent.com/-O...221_111648.jpg |
Anything done to them like cupping? I wonder if they will work on a 292 fastech
I believe B-Blades did add a little cup to them. I'm told it's a common recipe - used them for my 32 Active Thunder.
I now have Arneson drives with #6 props, otherwise I'd be running them. |
Interested. Possible to find out exactly what was done to them as far as the cupping goes?
Originally Posted by scarab63
(Post 4369498)
I heard back from B-Blades regarding the change in cup:
they told me cup was added near the tip and subtracted closer to the hub on the trailing edge. They mentioned it was one of their common recipes with the intent to add a little bow lift for a V-hull of this size while improving balance and overall performance. They have the props recorded in their system under a serial number for each prop and are happy to discuss them further with you. |
pm sent
Thanks for the pm, scarab, tried pm'ing you back but you inbox is full (was going to shoot you my phone #). Let me know in a week or 2 when you're ready to commit and i'll put a sale pending notice up. Thanks.
ttt
What kind of power and RPM did you put behind the props?
