598 ci bbc
4 Attachment(s)
Engine has 40 hours and made 800 + hp.... crower crank, carrilo rods, merlin heads, bowtie tall deck block.... lighting aluminum oil pan, early non leaking 2 piece valve covers and fluid damper .. Built by speed service in Chicago..Brian Doss .. Has a tunnel ram set on it.. but can change over to a single dominator carb set up.. roller cam 714 lift runs on pump gas 9.5:1 compression.. All the other parts not shown are new in boxes, ignition , etc...... will guarantee the engine components...Fresh water only use.. 9000.00 obo let's talk ... There is a matching engine also if you need twins.. Jay 239-437-9480
5 Attachment(s)
xtra pics
ttt
When was the last time this engine was running in a boat.
I need a single for a project boat. |
If that engine doesn't work out I have a 598 also with only 16 hours and it made 850 hp at 6000 rpm
Originally Posted by T31
(Post 4383235)
Originally Posted by dennis r
(Post 4383273)
Sorry not trying to hijack your post
Does this engine Run on pump gas or race gas. Thanks
| All times are GMT -5. The time now is 10:11 AM. |
