-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   used bravo 1 1.5 ratio gears (https://www.offshoreonly.com/forums/swap-shop/334488-used-bravo-1-1-5-ratio-gears.html)
indysupra 02-11-2016 08:44 AM
5 Attachment(s)
I have a used low hours upper gear set. 1.5 ratio(32/27). One of the brass rings has some chipping on a surface, other than that they are in great shape. At one time during my bravo blues I was buying spare gears and just repairing uppers with gears. I had MUCH better luck with these gears vs the xr gears. 550.00 plus shipping. Call or txt 317-538-3100. [ATTACH=CONFIG]550877[/ATTACH][ATTACH=CONFIG]550878[/ATTACH][ATTACH=CONFIG]550879[/ATTACH][ATTACH=CONFIG]550880[/ATTACH][ATTACH=CONFIG]550881[/ATTACH]
Sick Stinger 02-11-2016 09:45 AM
I believe I have a couple brass rings here if needed
Baja Rooster 02-11-2016 12:04 PM
As a fairly competent shade tree mechanic how difficult are these to drop in? The previous owner switched out the 1.5 for 1.65 and I wouldn't mind switching them back as I increase power rather than re-prop. Drop in, are is there some grey magic to it?
indysupra 02-11-2016 12:07 PM
They are super easy to change. Just need to check gear contact after assembly. You can buy the few tools you need off eBay for a few hundo. I think the guy who makes them posts on here.
indysupra 02-17-2016 10:15 AM
350.00
craigdskilling 02-19-2016 09:08 AM
I was told that I can use the bravo 1 upper gears for my Blackhawk drive is this true to be if so might be interested.
indysupra 02-19-2016 01:34 PM
Yes they are the same gear.
1989mach1 02-19-2016 03:25 PM
Are these the same as the b1x gears? And are the stock gears always 1.5 ?
indysupra 02-19-2016 04:20 PM
They are not the x gears
craigdskilling 02-20-2016 07:09 AM
how much for the brass ring.
