-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Marine Generator 8 KW Must GO (https://www.offshoreonly.com/forums/swap-shop/334631-marine-generator-8-kw-must-go.html)
Julie22 02-16-2016 09:12 AM
Westerbeke Marine Generator 8KW / Model Number is WTW-8.0-614 / Engine Serial Number is #178579-C602 / Generator Serial Number is #54268 / 8.0 KUA / Phase 1 / Volts 115/230 / AMPS 70/35 / Engine HP is 18.7 4 wire / 4 cylinder / gasoline. Generator was bought for a project and never used, you can here it run and we can show you the output AC total cost is $1,100.00 plus shipping if needed. Give us a call at 810-329-2908 or email me back at [email protected]
Julie22 02-22-2016 07:21 AM
This is a gasoline generator and if you want to use it for a home generator you will need to install a fan and a radiator
Julie22 02-22-2016 09:05 AM
5 Attachment(s)
Here are some photos;
[ATTACH=CONFIG]551372[/ATTACH][ATTACH=CONFIG]551373[/ATTACH][ATTACH=CONFIG]551374[/ATTACH][ATTACH=CONFIG]551375[/ATTACH][ATTACH=CONFIG]551376[/ATTACH]
Julie22 02-22-2016 02:11 PM
It does run good, turned over real easy, just needs a paint job, this is a good buy folks.
Julie22 03-02-2016 09:59 AM
Anyone know anyone that could use this.
