598ci 1300hp with 5.0 whipple
Big POWER marine engine top of the line build NO expenses spared, build cost was 75K!! Runs incredibly well, no issues with this motor!!
Peak Torque is at 1150 at 4800-5000 RPM 1326HP ON THE DYNO WITH ALL ACCESSORIES, WET HEADERS $30,000.00 obo 1326HP with race fuel 1190 with pump gas Mefi computer Merlin III 10.200 Block with Billet main caps Lunati Pro Series blower crank 4.5” stroke Lunati Parabolic beam billet rods JE custom forged blower pistons Total Seal TS1 Gapless rings Cleveite HN series bearings Hays billet steel flywheel-52 lb ATI Super Damper balancer Custom 14 Qt. offshore oil pan and pickup Melling High volume oil pump-blueprinted ARP oil pump drive rod ARP oil pump stud Billet aluminum timing pointer Custom ground hydraulic roller camshaft Morel High RPM roller lifters Manley pushrods AFR CNC cylinder heads Ported 357/385 Manley Severe duty intake valves Manley Extreme Duty Inconel exhaust valves ISKY valve springs Competition Cam springs cups, 10* retainers and locks HP valve stem seals Jesel Sportsman Series rocker arms ARP head studs Rear main seal Oil pan gasket Timing cover gasket Cometic head gaskets Bell housing dowel pins Brass freeze plugs Cam plug Fuel pump block off plate Whipple 5.0 serpentine belt system Whipple 5.0 efi supercharger remote 13 plate oil cooler whipple mo tec intercooler Hurricane Big tube headers Hurricane custom tails Hardin marine mufflers Imco hp transom plate with hydraulic steering Imco scx drive Upper Imco scx drive Lower 2101l90 Sea strainer 2101sr Sea strainer • 1300hp @ 6200 RPM • Torque 1000FT/LBS @ 2500 RPM • Always run AV 100 octane fuel |
So is the drive and transom assy is included with the motor?
Pics?
[IMG]http://i1030.photobucket.com/albums/...psi29fpekh.png[/IMG]
http://i1030.photobucket.com/albums/...psaly1iteu.png[/IMG] [IMG]http://i1030.photobucket.com/albums/...psytpfphdr.png[/IMG] [IMG]http://i1030.photobucket.com/albums/...ps4lpetiva.png[/IMG] [IMG]http://i1030.photobucket.com/albums/...pshweq67jw.png[/IMG] [IMG]http://i1030.photobucket.com/albums/...psa6v9cgrv.png[/IMG] |
Originally Posted by 598 Formula
(Post 4406096)
LOL, what boat is that in?!?!? thats a fast single
It's in a Magic Scepter 28
Pics and price of drive separately?
Can you better separate which items are included at the 30k asking price ?
Originally Posted by mach 1 2450
(Post 4406191)
[IMG]http://i1030.photobucket.com/albums/...psig5jpugg.jpg[/IMG] [IMG]http://i1030.photobucket.com/albums/...pssuyppw4a.jpg[/IMG] [IMG]http://i1030.photobucket.com/albums/...pstkkcd095.png[/IMG] [IMG]http://i1030.photobucket.com/albums/...ps4nbhw1io.png[/IMG] |
| All times are GMT -5. The time now is 07:46 AM. |
