-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Crane 133941 Cam and Lifters (https://www.offshoreonly.com/forums/swap-shop/335838-crane-133941-cam-lifters.html)
89Force235 03-26-2016 08:42 AM
About 20 hours on this cam. Comes with the crane lifters in a box matched to the lobes they ran on. I decided to go with something bigger. Lets say $80 plus shipping.
The specs from summit are below. Call text or PM. I'll try to post some pics later.
Thanks,
Travis
505 490 7710
Brand:Crane Cams
Manufacturer's Part Number:133941
Part Type:Camshafts
Product Line:Crane Hydraulic Flat Tappet Camshafts
Summit Racing Part Number:CRN-133941
UPC: 021174010831
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-5,000
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 216 int./228 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 284
Advertised Duration: 272 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.515 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.515 int./0.510 exh.
Lobe Separation (degrees): 112
Computer-Controlled Compatible: No
Grind Number: H-272-2
[IMG]http://i1198.photobucket.com/albums/...ps4wp3pktd.jpg[/IMG]
