Livorsi Monster Gauges
4 5/8" 8000 RPM Tachometer 4 5/8" GPS Speedo 2 5/8" Oil Pressure 2 5/8" Water Temperature 2 5/8" Fuel Level 2 5/8" Voltmeter Great condition. One has a slight imperfection on the bezel and one has a cut/modified rear bracket. $350 Shipped to your door. http://www.riverdavesplace.com/forum...6&d=1462770298 |
Do you have the antenna for the speedo?
I do not have the antenna. Just the gauge.
Is the antena still available for the gauge?
I'm sure it is. I believe Livorsi sells an upgraded version of the antenna.
Originally Posted by Chestah Cheetah
(Post 4439705)
Yea if it's a 2007 puck style antenna or older Lavorsi won't sell you a replacement and they will no longer service the dead battery in your antenna - (which requires a computer software reboot after install to work). I just found this out. Nice. Lavorsi will however sell you a completely new gauge and antenna for around $550. Nice way to drum up business. grrrrrrr
I'm trying a replacement antenna from Hardin Marine. I'll let you know if it works |
Originally Posted by Black Baja
(Post 4439708)
Any chance I can get I pic of the back of the gauge? If it's the old style the antenna is no longer available...
http://www.riverdavesplace.com/forum...5&d=1464204273 |
Can't get an antenna for that anymore. If you can source the tiny autometer 3 pin plug for the gauge you can run it of an old GPS plotter or something of the sort. Will not work with the new stuff and the plug is extremely hard to get...
| All times are GMT -5. The time now is 01:30 PM. |
