548 efi bbc-730 hp
I am selling the 548 EFI motor I built two years ago. Motor available as drop in complete with accessories and exhaust or long block with EFI and intake components. Fuel and oil systems optionally available (currently not installed on motor). Motor has ~50 hours on it. Was never on dyno but speeds achieved in boat support HP estimates. The bad: Last run of last season, engine spun a rod bearing at sub 3000 rpm speeds and was immediately shut off (was actually during getting on plane for first time of day). Never lost oil pressure. I have invested over 21k in parts alone. Great deal for someone who is willing to fix a rod bearing to save ~50% of the cost of these components new.
Many photos available by request. Please send me a PM with your contact information for questions. All prices OBO. Not willing to split components unless all respective pieces spoken for with deposit. Long Block with EFI: $11k Long Block with Exhaust and Accessories: $13k Fuel system: $400 Oil system: $400 Happy to crate and deliver to freight dock for shipping at buyer's expense. Parts List for long block: GMPP Gen VI Bowtie Block 4.530 bore Ohio Crank 4340 forged 4.25" stroke crankshaft (internal balance) Neutral balance flywheel Engine Pro (Manley) 4340 H-beam rods with ARP 2000 bolts Probe mini-dome pistons 4340 forged (10.2:1 CR) with Total Seal conventional AP ring pack (SS top ring, Napier 2nd, STD tension oil rings) AFR 335 heads with cnc chambers and runners, equipped with AFR stainless intake and inconel exhaust valves, Isky Tool Room springs, Dart adjustable guideplates, Chrome moly retainers ARP head bolts and rocker studs Harland-Sharp endurance 1.7R roller rockers Webber Industries stud girdles Custom .120" wall hardened pushrods Cam Motion (Morel) High RPM hydraulic roller lifters Custom Marine Kinetics cam (.690" lift, full specs upon request) Cometic MLS head gaskets Edelbrock 454-R dominator-flange intake setup for MPI fuel injection and port matched to heads Accel DFI 2100 CFM dominator-flange throttle body with 1" spacer Holley HP ecu, harness, sensors, LS3 coil packs set up for C-N-P distributorless ignition Holley 43 lb/hr fuel injectors Mallory billet distributor hole plug/oil pump drive 8 qt. oil pan Eddie Marine bypass crossover/thermostat housing Billet oval arrestor/air cleaner Merc starting/charging harness with plug Starter Teague Aluminum valve covers with Hardin Extreme breathers Exhaust: EMI Thunder manifolds with long SS risers with dual O2 sensor and single EGT port installed Fuel System: Aeromotive A1000 pump Aeromotive EFI regulator 2"x10" fuel cooler Oil system: Teague 3"x18" oil cooler 210* oil thermostat Dual parallel oil filter head Dual oil temperature gauge senders/ports Block adapter All hoses/fittings are 1/2" NPT with 5/8" ID lines Accessories: Merc PS pump with cooler, Bravo sea pump, 100A Delco alternator, brackets and V-belt setup Mercruiser engine mounts Mercruiser bravo bellhousing New bravo engine coupler http://i734.photobucket.com/albums/w...ps1b8jizoz.jpg http://i734.photobucket.com/albums/w...pshatd20y4.jpg http://i734.photobucket.com/albums/w...pstfpwakhl.jpg http://i734.photobucket.com/albums/w...ps53g4bcs6.jpg http://i734.photobucket.com/albums/w...psgfogmm8k.jpg http://i734.photobucket.com/albums/w...psqheo1qz3.jpg http://i734.photobucket.com/albums/w...pslxielzig.jpg http://i734.photobucket.com/albums/w...psyof1erpp.jpg http://i734.photobucket.com/albums/w...ps0bp9586w.jpg http://i734.photobucket.com/albums/w...psv2akge2s.jpg |
I was looking at building something similar to this to put in my cat this winter I would be interested in the total package were are you located
I am located near Midland Michigan. PM sent with my contact info.
Bump
If you havent sold this by wintet and you start tearing it apart we should try your intake on the dyno!
Originally Posted by articfriends
(Post 4474832)
Sunday Bump. Make me an offer.
Bump. Make me an offer. Lets talk.
Pm me what's the price you will take for complete set up
Originally Posted by 26ftfirehawk
(Post 4494889)
| All times are GMT -5. The time now is 10:18 PM. |
