Mercury ITS/ Fully Rebuilt by Collabella Performance
Mercury ITS Transom Assembly
These have the 7inch standoff built into them along with full hydraulic steering and HP Transom/ Gimbal assembly! ALL Bearings and Bushings Replaced with New! These are similar to Mercury #6 setups but designed for Bravo Drives. They are the same transom assemblies that Snowy Mountain Brewery and Tuff Marine both ran in the LOTO Shoot Out last week. Both Boats ran faster then 117mph with single engine setups! Very Clean transom appearance, All hoses and cables run inside gimbal. Nothing exposed except drive and cover. I have 2 of these ITS's being rebuilt by Craig Collabella, I only need one for my application. These are being rebuilt to Racing standards! I will be racing the one I install on my 30ft SVL. Can be available in less than 3 weeks! $4500 obo Call or text for pictures or questions. 239-443-8233 |
ttt
Hi, what year is the ITS Box, would you send some Fotos? George
These are off a twin engine application, pushed by '05 Merucry Racing HP525 efi's. George, text me your email so I can send pictures, I should have pictures in a day or two.
bump
Craig has not disassembled these as of yet.
Only thing that needs replacing is top bushing, just a little sloppy, nothing bad! If someone wants to have the repair done for themselves, I will sell one for $2500 as is. $4500 after complete rebuild! These units are $8300 new! There is almost NO corrosion and these look almost like new! Text or call if you want to see pictures. Rebuild will probably start at end of next week, so let me know if you want one as is. 239-443-8233 I also have access to a ITS Yoke for $125 if you need one! |
9 Attachment(s)
[ATTACH=CONFIG]559382[/ATTACH][ATTACH=CONFIG]559374[/ATTACH][ATTACH=CONFIG]559375[/ATTACH][ATTACH=CONFIG]559376[/ATTACH][ATTACH=CONFIG]559377[/ATTACH][ATTACH=CONFIG]559378[/ATTACH][ATTACH=CONFIG]559379[/ATTACH][ATTACH=CONFIG]559380[/ATTACH][ATTACH=CONFIG]559381[/ATTACH]
ttt
Are you selling one or two units?
baja27, clear your inbox or give me a call!
239-443-8233 |
| All times are GMT -5. The time now is 12:13 PM. |
