-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Gen 7 Seawater Pump (https://www.offshoreonly.com/forums/swap-shop/342463-gen-7-seawater-pump.html)
Knot 4 Me 11-07-2016 07:24 AM
Gen 7 Seawater Pump
2 Attachment(s)
Replaced my brass Gen 7 seawater pump with a stainless Hardin unit. You reuse the back housing with the water inlet/outlet so I only have the front part of the pump for sale. It is off an early (9/03 build date, OM683216) 496 MAG that had 400 hours on it when removed. All freshwater, rock or clay bottom lake use. This pump has never had sand, mud or anything else ran through it. I never boat in shallow water. Pump turns smoothly and there is no scoring on the impeller vane surface of the pump housing. There is a minimal amount of scoring on the impeller face surface at the front of the pump as can be seen in the pick. Make offer. I will even toss in a new impeller/o-ring kit (47-862232A2). Thanks.
Knot 4 Me 11-14-2016 10:34 AM
Monday bump day. This is a cheap way to get back out on the water if you have one spit the shaft out which some of these have been know to do.
Knot 4 Me 01-17-2017 09:02 AM
Mid-winter bump. If a fellow OSO'r can put it to use, pay for the new impeller and I'll toss in the pump/pulley for free if you pay shipping. Really don't want to toss it in the garbage. Thanks.
Sick Stinger 01-17-2017 09:20 AM
Let me know how much. I'll take care of it.
Knot 4 Me 01-18-2017 07:16 AM
Sold!
