Bravo 1 swept back outdrive
2 Attachment(s)
[ATTACH=CONFIG]565103[/ATTACH][ATTACH=CONFIG]565102[/ATTACH]I have a Bravo 1 outdrive , came with the boat, according to the seller it has only 10 hours on it. It has the upgraded X Gears 1.5 ratio, I haven't had it apart to verify. I just pulled the engine and upgraded power so I installed the XR drive. You can text me @ 510-750-2609 for pictures.The outdrive is near perfect condition, no corrosion whatsoever. $3500 plus the ride. I also have an XR drive very low usage with an SEI lower 1" shaft. $4500 plus the ride.
| All times are GMT -5. The time now is 02:01 AM. |
