-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Fresh 565 bbc (https://www.offshoreonly.com/forums/swap-shop/345437-fresh-565-bbc.html)
dennis r 03-14-2017 07:20 AM
Fresh 565 bbc
2 Attachment(s)
Dart big M block with steel main caps
Crower crank ,crower rods ,JE pistons,harden marine 12 qt oil pan,AFR 355 CNC heads, crane rocker arms, stud girdle , dart intake 1050 Holley carb, MSD ignition, hydraulic roller cam ,Isky lifters stainless intake valves inconel ext valves
$9000 plus shipping
dennis r 03-15-2017 04:24 AM
What is it going to take to sell this motor
dennis r 03-16-2017 12:23 PM
Ttt
dennis r 03-19-2017 08:39 PM
Bump
Tinkerer 03-19-2017 09:19 PM
Dennis I may still want to see if these would fit my boat. I will have to remove a tail to see where the hole needs to be made.
I need to have some work done on the boat and as long as the tail doesn't exit the transom up where the transom angles forward then they will fit and solve the problem of the exhaust blowing on the hydraulic steering.
Let me know if this is OK with you.
dennis r 03-20-2017 04:30 AM
That's fine just let me know
dennis r 03-22-2017 08:57 PM
I sold the headers so just the motor
dennis r 03-29-2017 11:48 AM
Motor only
