1978 28 mirage part out
5 Attachment(s)
1978 mirage part out. Has a soft transoms other then that it's solid.
454 420 motors low hour from what owner said 75 range. 3500 each 4500 with exhaust 8000 for both with exhaust 72C green tag trans BW 700 each 1200 for both 25P mirage props 350 Hynautic full hydraulic steering 2000 TRS or I have a bravo plate also TRS drive 2500 for the pair Transoms for parts 700 both Indicator set up 450 Tabs 1000 compete Trailer BOS 2500 Bolster seats 400 Batt boxes 75 both Mufflers 200 a set Bellhousing a 100 each have a stack of them Torque plates 100 have a stack Controls 200 Anything else please ask. [ATTACH=CONFIG]566042[/ATTACH][ATTACH=CONFIG]566043[/ATTACH][ATTACH=CONFIG]566044[/ATTACH][ATTACH=CONFIG]566045[/ATTACH][ATTACH=CONFIG]566046[/ATTACH] . |
how much for the map/chart box?
Let me see how easy it is to remove , hate to break it.
what condition is the exhaust in
controlles n cables ?
Fresh water since new I'm told. Should be all in nice shape.
Controls and cables 225 shipped sound fare? |
Did you get a chance to check out the chart box? Do you have any pictures of the cabin teakwood? My boat is missing a lot of it.
I will see what I can do with pics. The interior is compete and in nice shape.
how old is the exhaust and can you pressure test them. also will you separate the drives.
I have a couple drives here if you need TRS
I can pressure check age I do not know. |
| All times are GMT -5. The time now is 06:28 PM. |
