Bravo 1 30p LH Modified
This is a 30ph LH Bravo 1 that has been modified.
It has been cut down to 14.75 diameter and Labbed, The Exhaust barrel has been shortened 1". It has a 29 Stamped on it (Assuming Measured Pitch). Not sure what this would be used on. I bought to test, only knowing it was a 30p LH B1. Found it to be modified when I received it. Had it cleaned up at a local prop shop and tested it on my boat(27 Fountain 496HO). My only assumption is that it is for a deep X dimension or Outboard setup of some type. It did not like any Torque and seemed like it needed to be spun faster. Any insight on what this would be used for is welcome also. The best comparison I have found is a Bravo 1 OC Prop. http://www.mercuryracing.com/propell...rd/bravo-i-oc/ Will Ship to your Door for $325. Thanks Mike http://i128.photobucket.com/albums/p...psh96axtcu.jpg http://i128.photobucket.com/albums/p...psdkc7vhql.jpg http://i128.photobucket.com/albums/p...pssm8vaj1e.jpg http://i128.photobucket.com/albums/p...pstwajvpb3.jpg http://i128.photobucket.com/albums/p...pslxojhhln.jpg |
| All times are GMT -5. The time now is 06:22 AM. |
