-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Boat Engine (https://www.offshoreonly.com/forums/swap-shop/347986-boat-engine.html)
Yves0009 06-27-2017 08:25 AM
Boat Engine
6 Attachment(s)
PRICED AT $29,995! FOR EVERYTHING THESE ARE HIGH DOLLAR BUILDS WITH THE BEST PARTS YOU CAN BUY – Matched set of 705 CI 1400 HP Marine engines the Pro Marine Havasu DYNO (10 hours) INCLUDESES STELLINGS BIG TUBI HEADERS (freshly polished and pressure tested perfect) INCLUDES STEELINGS TAIL PIPES, INCLUDES SCS CRASH BOXES (zero hour rebuilds from SCS Gearbox and fresh paint) Dart blocks 4625 Bore 5.250 Stroke, Sonny Bryant Cranks, Matton Rods, J&E Pistons, BDS 14-71 Superchargers (restriped, rebuilt, and repolished zero hours) Stefs Oil Pans, 904 Lifters, Jasel Super Duty Shaft Rockers, Comp belt drivers, MSD marine ignition and marine distributors, New style Hardin Intercooler sand strainers, new edition Dart 380 cylinder heads, customer “no mess” valve breathing system, Holly 1050 Dominators, Hardin 3 stage water pumps, Mercury racing mounts, bell housings and coolers, billet aluminum lifting rings, Keith Eikert 2 piece valve covers. All fluid lines are black nylon braided hose with matching black fittings. These engines are designed for super low maintenance and reliability. The cubic inch of these engines allow for Huge torque output at low RPM and the torque stays high without the need for excessive RPM No valve train issues that kill Marine engines and the will never be a problem with these engines.
F-2 Speedy 06-27-2017 09:14 AM
OK, I'll bite,,,,,,why so cheap, its worth about twice your asking price, if you really do mean FOR EVERYTHING
kreed 06-28-2017 06:16 AM
WOW...dirt cheap!
