- - Bravo 1 and Maximus prop sets
(https://www.offshoreonly.com/forums/swap-shop/352547-bravo-1-maximus-prop-sets.html)
pstorti
03-21-2018 02:28 PM
Originally Posted by kakarot
(Post 4617077)
What were the slip numbers before and after the cupping was removed from the maximus ?
I don't keep track of slip numbers because they don't equate to any improvement in performance in my case, and they often are inaccurate. The stock 24 Maximus gave me very low slip numbers but poor mpg and slower top end compared to 26 Bravo. The problem with calculating slip is that you are assuming the pitch stamped on the prop is accurate, and it usually isn't.
My boat has EGT sensors, very precise fuel consumption sensors, so I go by those numbers, rpm's and gps speeds to tell me if the props are doing what I want or not.
Removing the cup for me brought them closer to the mpg I get with the Bravos, while still giving me the better low speed and midrange cruise.
pstorti
03-23-2018 02:10 PM
The 26 Bravos and 24 Maximus are sold.
25Orion
03-25-2018 12:32 AM
Originally Posted by pstorti
(Post 4615031)
Muratic acid
i tried a little maybe not enough, but what’s the process you use? Love how shiny these are
1989mach1
03-25-2018 05:29 PM
If it helps I use zep toilet bowl cleaner. Spray it on with a pump sprayer let sit spray it off. And if need be repeat.I'm on a lift and do my pros and bottom twice a month if I can and if it needs it.
pstorti
03-27-2018 05:31 PM
Originally Posted by 25Orion
(Post 4617817)
Are your props already polished or do they have a satin finish? No cleaner will put a mirror shine on the props if it is not already there.
Maikel
12-16-2020 09:30 AM
Do you got the 26p Mercury Bravo 1 set still for sale ?
