BBC Procharger Supercharger Kit, Mostly Complete
BBC Procharger D1 partial kit with an ATI AW-504 air/Water intercooler. D1 Head unit is brand new, have 12 rib crank 7.75 pulley, and 12 rib 3.90/3.70 blower pulleys. BBC Mount bracket and procharger bypass valve. Will need belt and tensioner assembly, and piping from the blower to the IC and to the carb, also have a quick fuel blow through 750 carb, was used on a twin turbo 5.3 making ~800 HP. Asking 4500 for everything. With the 7.75 crank pulley and the 3.70 blower pulley it puts the blower rpm just under its 65K RPM max at 7K engine rpm. I was building a 396 BBC to put this on for my 68 Rayson-Craft jet boat project but have decided to do an LS engine on the Jet boat. The D1 is not self contained so it will require an oil feed and return on the engine and can support 925HP at a max of 30psi. The needed pieces to complete this can be had for less than 500 from procharger or less if you can score some good used pieces. The AW-504 is rated for 1200+HP. Get a great deal for easy bolt on horsepower! |
Pics? |
Originally Posted by Mrhorsepower
(Post 4617221)
Pics? https://porthuron.craigslist.org/pts...533584602.html |
| All times are GMT -5. The time now is 10:18 AM. |
